solid thinking inspire has stopped working
i have installed Hyperworks and Solidthinking according to the steps shown on website , but i am having problem with the solidthinking inspire 2016. inspire is not starting properly , hyperworks and solidthinking evolve are working properly but when i open inspire (the display says that it has stopped working) . please help me with this problem . i have the student license version of hyperworks and solidthinking.
i have also attached the image of display for reference.
Could you tell us the operating system and other machine specifications like the graphics card etc. (enter dxdiag in start > run and send us a snapshot of the display tab)
If you are using windows 10 the software is not supported, also check about the graphics card as in the below post.
0 -
Please have a look at this post on the solidThinking forum and let us know if it helps with your issue.
Matthieu
0 -
If you encounter the message below when starting Inspire on Windows 10, we have a workaround for you:
In your Start Menu, go to your Inspire shortcut, right-click, choose More then Open file location:
In the window that opens, right-click on the Inspire shortcut and choose Properties.
If your Inspire shortcut is on your Desktop, directly right-click on it and choose Properties.
In the Properties window, switch to the Compatibility tab, under Compatibility mode, check Run this program in compatibility mode for: and choose Windows 8 from the drop-down. Click on OK and try starting Inspire again.
