🎉Community Raffle - Win $25
Join and Win
Can't load Nastran xbd file with modal results in Hyperview 12
User: "Altair Forum User"
Updated by Altair Forum User
I can't seem to load an Nastran xdb file into Hyperview 12.0 when there is modal analysis (sol103) data in the results file.  It always seems to hang up.  I can read the same file in Patran, but I would rather use Hyperview.  Does anyone have the same issue?
1 - 2 of 21
    OP
    Close all your HyperWorks application on your machine and follow the below:
    Please delete setting files on your machine. Follow the link below on how to delete setting files:
    http://forum.altairh...iles/?hl=delete
    Also, delete .Altair folder in temporary directory. Go to Run and type in %Temp% and click OK (see the picture below)
    Now open HyperView and try loading the file.
    Please note: If you are a commercial customer, you can contact your local support for a quicker solution http://www.altairhyp...ortProduct.aspx
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-14718000-1410412057_thumb.jp
    OP
    Also u can try .OP2 output file. Just replace PARAM, POST, 0 in bdf file to PARAM,POST,-1.
