How to Extract the component name from selecting node / element.
Altair Forum User
Altair Forum User
hi there,
i am trying to resolve the problem of extracting the component name.
1) if i am selecting the node / element.
2) then how to identified that which component name is that nodes / element is belongs too.
please resolve this issue.
Regards
Adams
Welcome!
  • tinh
    tinh Altair Community Member
    edited April 2014
    Hello
    try hm_getentityvalue nodes nodeid collector.name 1 -byid
    please read topic about 'data names' in hypermesh help
  • Altair Forum User
    Altair Forum User
    edited April 2014
    hi tinh,
    set a [hm_getmark nodes [*createmarkpanel nodes 1]];
    'set b [hm_getentityvalue nodes $a 'collector.name' 1 -byid] '
    puts 'col name : $b'
    it is not returning the name of the collector.
    Regards
    Adams
  • tinh
    edited April 2014
    Hello Adams
    it should be:
    *createmarkpanel nodes 1 'Select a node';#this is an interactive command
    set a [hm_getmark nodes 1]
    set b [hm_getentityvalue nodes $a collector.name 1 -byid]; #if you did not or selected more than one node, this command will raise an error
    puts 'col name: $b'
  • Altair Forum User
    Altair Forum User
    edited April 2014
    Hi tinh,
    with the code listed above i am not able to retrieve the name of the component.
    but when i am taking element as an entity then component name is extracted.
    in my problem set node is important, i want to extract the component name while selecting node only.
    thanks
    Adams
  • tinh
    edited May 2014
    oh,sorry i forgot that one node can be belonged to 2 or more than 2 comps
    so if you have a node, first find elements attached to it
    *createmark nodes 1 $nodeid
    *findmark nodes 1 1 1 elems 0 2
    set elems [hm_getmark elems 2]
    foreach elemid $elems {puts [hm_getentityvalue elems $elemid collector.name 1 -byid]}
Welcome!
Welcome!
