I proceeded in the same way as the video on your InspireCast page but couldn't fix the meshing issue. May you help?
If you provide me your setup file(.icast) , I would investigate the cause of mesh fail.
Thank you.
Hello, If you provide me your setup file(.icast) , I would investigate the cause of mesh fail. Thank you.
I added the file.If you can fix it, can you go out to me step by step? I just started using the program.Thanks, in advance.
here the icast file
