Hello to all,
I'm new here and I don't know if this is the correct section where to post (if it's not correct I apologise in advance).
I'm studying a physical meander line antenna printed on a PCB and there is no ground plane beneath the antenna.
Do you have any advice how to set the ground in FEKO? Is it mandatory to have a ground plane for the simulation?
Your opinions are more than welcome,
Thank you
Manuel
