I've checked the forum and found another post on this but what was expressed in that thread was an older version and it seems the answers may have changed. I basically am having a problem with some of my solid TRIA elements and their numbering. Currently, I'm getting an error that says,
' *** ERROR #2502 *** Element 2369226 had innocent node numbering sequence and needs renumbering.'
which was repeated twice. If anyone has any advice or help, that would be much appreciated! Also, it mentions something along these lines,
' Note: Please import the model into HyperMesh and export it. This will fix the problem related to the incorrect node numbering. Another option is to use PARAM, RENUMOK.'
which I tried and didn't find much success on (There isn't even an option for PARAM, RENUMOK in the control cards in version 13.0).
Dylan Stelzer
