Quad meshing of a femur 3-D model
Hi there,
I am working on a project and my goal is to assign patient-specific bone material properties to a 3-D model created from a set of CT-scans. To do so, I have a segmented 3-D model of the femur resurfaced using solidworks. I have another software called BoneMat that assign the material properties to the bone using the CT-scans as well. But in order to do so, I have to import the bone model as a meshed neutral file (*.ntr). It is my first experience with finite element modelling, and I was wondering if anyone could help in how to mesh my already segmented 3-D model (saved as a .igs that I can import in HyperMesh) and I want to be able to create that (.*ntr) file using this software.
Thank you for your help
In that case, do you know how can I output a neutral file using HyperMesh? because when I try to export in ASCII format, it says connectors have not been selected even after I mesh my file!
Thank you again for your help
With a customized FE output template, you can export the mesh to any (ascii) format.
That is exactly what I tried to do and it still shows me the following error message:
Thank you
I could have a look at your model, if you want /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Hi everyone,
I am looking on how to get a Patran Neutral File using Hypermesh. I have the trial version of Hypermesh, could you please confirm that it is not because of a limitation in the version that I cannot find a way to get that neutral file?
Thank you
Hi rdam,
I can not found Patran Neutral File in supported format of Hypermesh version 12.0.
Maybe you have to try with another format.
I figured out how to get the Neutral file. Thank you for your help.
I have another question,
How can I create HEX elements using HyperMesh? I am trying to mesh a femur!
Thank you
Hi rdam,
I have just started working in the FEA area, and I am trying to create a suitable mesh for a lumbar vertebra (L4) and in the end the L4-L5 motion segment (i.e. L4-intervertebral disc - L5).
For this, I have created a 3D cad object from CT data and imported it as an iges file into hypermesh, where I surpressed all edges but one, and used automesh (only trias) to create a new 2D mesh.
However, I want to have different element sizes for different parts due to computational efficiency that have the same element density where they 'meet' , any ideas on how to achieve this?
Also, how do you mesh the difference between cortical and trabecular bone?
Thanks in advance!
i don't know the *.ntr format and i don't know if it is supported by Hyperworks.
IGES files you can importing and meshing in any case. But the reference to the right material properties is still a task.
Which preference (solver) do you want to use to solve anything and which material do you use inside the preference?
Mario
