so since Hyperworks works in N,mm,MPa, do i consider N*mm as units for moment load?
Hypermesh in non-dimensional. It is up to the user to use consistent units and convert values accordingly at each instance.
Yes, when using N,mm,MPa, use N*mm as units for moment
Hypermesh is Non-Dimensional but for our ease by default one can keep Force in N, Displacement in mm,Time in S and Mass in Tonne..... U can see that while assigning the materials the unit of density will be in tonne/mm3 by default i.e by default when we click for the density in the material collector it displays density of steel as 7.9e-9 which is conversion of density of steel 7900 kg/m3 to 7.9e-9 tonne/mm3
