Hello all,
I am from a Geophysics background and I am attempting to use HyperMesh to generate a FE Mesh of some basic reservoirs containing different fracture or fault geometries
I am trying to mesh a a simplified model of a reservoir (volume) with two embedded intersecting faults (surfaces). I attached a picture of my simple geometry to give you an idea. I need the finite element mesh for flow simulations, however the simulation requires that the triangle elements of the fracture surface have shared nodes with the tetrahedron elements of the volume.
I was able to generate a mesh successfully, however it does not seem to have shared nodes because when I run my simulation there is no communication (fluid flow) between the fracture and the rest of the volume.
Can anyone help me with this issue? Is there a particular setting that I need to use to ensure that there are shared nodes between the surface and volume elements.
Currently, I mesh the surfaces first, using 'Create 2D AutoMesh' then create the volume around it and I mesh that using 'Tetra Mesh'
I would greatly appreciate any feedback you can give on this.
Thanks,
Ariel
