How to view the AAA.res file generated after solving the analysis?
You need to go to File > load > results within HyperMesh
.res is a HyperMesh results file.
can i read a '.out' file in Hyperview?
you can read an .out file with any text editor ( like notepad)
Could you please let me know why you want to open a .out file in HyperView?
.out files contains information about the solution and run/optimization history and it cannot be opened in HyperView.
because i wrote a matlab routine and would like to read it in HiperView
so i would try to obtain my results in matlab with a similar syntax to .out file, for example, to be able to read it in HiperView
Out file is not the way for that,
see http://forum.altairhyperworks.com/index.php?/topic/13513-evaluation-of-barrier-load-cells-with-hypergraphhyperview/?hl=%2Bascii+%2Breader#entry18776
Hi Rahul,
thank you very much!!
Regards
André Cerávolo
