Good afternoon.
I am using FEKO in order to get platform installed antenna pattern.
In our project, I get the platform model as a surface model.
When I mesh the model without changing any thing on model, I take multiple same errors for which one of the errors is given below.
'The triangles 15299 and 123263 touch, but they do not have a common edge.
Received message from server process 2:
ERROR 832: Segmentation rules have been violated (two triangles touch without a common edge)
Aborted: 2022-04-21 16:33:13'
How can I solve this kinds of errors?
Should I check all of the erroneous edges and triangles.
I couldn't share the .cfx file or out file due to security related things.
Thank you.
Regards
