Hi All,
FYI, the model is a sandwich panel (with aluminium honeycomb at center and one layer of carbon on each side- top and bottom) used in monocoque. Well, I am stuck at meshing of honeycomb and unable to get consistency in results.
While trying on the actual cut sample (LxW- 368mm x 176mm), I got 'volume analysis failed' and 'temp_2d_for_tetra' for many a times and so I thought I should try on a small pattern (70mmx35mm). After trying on a small pattern, the carbon layers are not attached while viewing in HyperView, i.e. honeycomb deforms individually and carbon layers deform separately at higher frequencies. I created the assembly in SolidWorks ('mate' in assembly file) at first, it gave the results as mentioned above (carbon layers not attached with honeycomb).
Next I created lines on outer edges of honeycomb in HyperMesh (to develop carbon layer), assigned thickness (of carbon) and meshed it; but in both cases, the honeycomb is not attached to carbon (while viewing '.op2' file in HyperView).
Can you please help me out with this? Much appreciated.
Thanking You.
Kind Regards,
Shreerang
