How can I make the scrollbar work properly ???
User: "Altair Forum User"
Updated by Altair Forum User
Hi all of you guys,
Actually Im trying to make a browser tab with scrollbar (because in my situation, there are many widgets in the browser tab so we dont have enough space for them), however I could not make it work properly...!!!
If anybody who know how to do it, please help me to solve the problem.
here I attached my code for your convenience
your help will be appreciated
Thanks
# making tab in the browser
proc Make_TAB { } {
    lappend auto_path{<path to the folder containing hwt folder>}
    package require hwt; #to import the hwt package
       set tabName 'System_Parameters';
     hw browser delete $tabName;
    hw browser add $tabName end [ hw browser get frame $tabName ];
    hw browser select $tabName;
     set frm [ hw browser get frame $tabName ];
    set bclose [::hwt::CanvasButton $frm.bclose [::hwt::DluWidth 8] [ ::hwt::DluHeight 8 ] \
        icon  msclose  iconH   1  iconV   1  \
        relief  flat  help  'Exit Program'  takefocus 1 \
        command 'hw browser delete $tabName' ];
    pack $bclose -side top -anchor ne -padx 5 -pady 5 ;
#---- how can I make the scrollbar work properly ??? --------
 set scrb [scrollbar $frm.scrb -command '$frm yview']
 pack $scrb -side right -anchor nw;
    set labelWidth 27;
    set entryWidth 15;
    #section label
    set section1 [label $frm.section1 \
        -text 'SYSTEM PARAMETERS' \
        -justify left \
        -anchor nw \
        -font [hwt::AppFont]];
    pack $section1 -side top -anchor nw;
    hwt::AddPadding $frm -side top -height [hwt::DluHeight 5];
    # frame1
    set frame1 [frame $frm.frame1];
    pack $frame1 -side top -anchor nw;
    hwt::AddPadding $frame1 -side left -width [hwt::DluWidth 15];
    set entry11 [ hwt::AddEntry $frame1.entry11 \
        -label 'Mass (kg)' \
        -labelWidth $labelWidth \
        -entryWidth $entryWidth \
        -text '' \
        -textvariable mass_rocket \
        -validate real \
        -state normal \
        -withoutPacking];
    pack $entry11 -side top -anchor nw;
    set entry12 [ hwt::AddEntry $frame1.entry12 \
        -label 'Force (N)' \
        -text '' \
        -textvariable mass_b2 \
        -validate real \
        -state normal \
        -withoutPacking];
    pack $entry12 -side top -anchor nw;
    hwt::AddPadding $frame1 -side bottom -height [hwt::DluWidth 380];
    # buttons Load_Initial_Model, Run
    set btn1 [button $frm.btn1 -width 16 -height 2 -text {Load Initial Model} -command {Open_Model}];
    pack $btn1 -side left -padx 22 -pady 5 -anchor nw;
    set btn2 [button $frm.btn2 -width 16 -height 2 -text {Analysis Setting} -command {Analysis}];
    pack $btn2 -side left -padx 16 -pady 5 -anchor nw;
# end proc Make_TAB
# main code
    set isFirst True;
    Make_TAB;
# end main code
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    Maybe we cannot scroll a frame
    Try using a textbox with scrollbar, and put your widgets on it
    using hwt::CheckScrollBars $textName $textWidth $textHeight to add scrollbars to the textbox
    OP
    Dear tinh,
    First Im greatly appreciated your kindness reply. Actually, I tried many times for making the textbox with scrollbar on the browser tab, however it still can not work properly ... here I attached my tcl code, if you dont mind please help me to add scrollbar so that it work properly.
    your help will be highly appreciated
    best regards
    MDD
    hw browser add $tabName end [hw browser get frame $tabName];
    pack $bclose -side top -anchor ne -padx 5 -pady 5;
    # -----please help me to add scrollbar with the box-----------
    set box [hwt::AddCanvasBox $frm withbothScrolls]
    pack $box -anchor nw -fill both -expand 1 -padx 4 -pady 4;
    User: "tinh"
    Updated by tinh
    Hi, did you overcome the problem?
    try download bwidget package and put it in hw/tcl folder
    below is sample code
    #set up tab
    set tabname tinh
    set frmname .tinh
    destroy $frmname
    hm_framework removetab $tabname
    frame $frmname
    hm_framework addtab $tabname $frmname
    #set up scrollable frame
    set frmgrand [frame $frmname.frmgrand]
    set frmparent $frmgrand.frmparent
    package require BWidget
    ScrollableFrame $frmparent
    set frmscroll [$frmparent getframe]
    set hscroll [scrollbar $frmgrand.hscroll -orient h -command '$frmparent xview']
    set vscroll [scrollbar $frmgrand.vscroll -orient v -command '$frmparent yview']
    $frmparent configure -xscrollcommand '$hscroll set' -yscrollcommand '$vscroll set'
    #set up layout
    grid $frmparent $vscroll -row 0 -sticky news
    grid $frmparent $hscroll -col 0 -sticky news
    grid rowconfigure $frmparent 0 -weight 1
    grid columnconfigure $frmparent 0 -weight 1
    pack $frmgrand -anchor nw -fill both -expand 1
    bind $frmgrand <Configure> '$frmparent configure -width \[expr %w - \[winfo width $vscroll\]\] \
    -height \[expr %h - \[winfo height $hscroll\]\]'
    #just for test
    for {set i 0} {$i < 10} {incr i} {
    set frm$i [frame $frmscroll.frmtest$i]
    pack [set frm$i] -side left -anchor nw
    for {set j 0} {$j < 50} {incr j} {
    set btn$j [button [set frm$i].btn$j -text Button$i$j]
    pack [set btn$j] -side top -anchor nw
    OP
    Dear tinh,
    by following your code & advices, finally my problem has solved.
    Im greatly appreciated your kindness help, especially spending your time and effort for making the demo script.
    again, thanks you very much for your kindness help.
    best regards
    Mai Duc Dai
