I'm a mechanical students that needs to work on hyperXtrude in order to test a designed die and see if it will be good for extrusion, but unfortunately i don't know how to work with hyperxtrude. so please can someone give me some beginners tutorials and how to start a simple study .
Thank you all
There are extensive tutorials in the help documentation to get started with HyperXtrude,
Manufacturing Solutions Tutorials > HyperXtrude Tutorials
Introduction
HX-0000: Introduction to HyperXtrude
Metal Extrusion
HX-0001: Importing Die Geometry
HX-0002: Create and Edit 3D Solids
HX-0003: Creating Die Geometry for Solid Profiles
HX-0022: Mesh Generation for Solid Profiles
HX-0023: Mesh Generation for Hollow Profiles
Guidelines for Non-Hex Meshes
HX-0052: Bearing from Nodes
HX-0053: Define Bearing Profile from Control Lines
HX-0054: Bearing Creation from 3D Bearing Curve
HX-0100: HyperXtrude Analysis - Extrusion Wizard
HX-0101: Extrustion of a Solid Profile
HX-0102: Extrusion of a Solid Profile Die with Pockets
HX-0104: Modeling Dies with Symmetry Planes
HX-0105: Solid Profile Die with Multiple Exits
HX-0106: Indirect Extrusion - Solid Profile
HX-0107: Solid Profile Using Existing Mesh
HX-0108: Hollow Profile with Existing Mesh
HX-0109: Mesh Generation using Solid Map Option
HX-0151: Extrusion of a Hollow Profile
HX-0155: Indirect Extrusion of a Hollow Profile
HX-0201: Tool Deflection
HX-0302: Variable Time Step Analysis
HX-0303: Billet Skin Tracking
HX-0304: Transverse Weld Length
HX-0401: Select/Add New Material Properties
HX-0404: Fit Material
HX-0427: Add New Presses to the Database
HX-0452: Bearing Length Optimization using HyperXtrude and HyperStudy
HX-0500: Introduction to HyperView
HX-0501: Post-Processing
Polymer Processing
HX-1000: Overview of Polymer Processing Tutorials
HX-1001: Geometry Cleanup
HX-1003: Creating Solids for Meshing
HX-1022: Mesh Generation for Solid Profiles
HX-1151: Profile Extrusion using Plate Meshing Wizard - Single Hole
HX-1152: Free Surface Deformation Analysis
HX-1153: Profile Extrusion Using Plate Meshing Wizard - Multiple Holes
HX-1154: Boundary Conditions
HX-1201: Analysis of a Wire Coating Die
HX-1202: Coextrusion Analysis
HX-1251: Calibrator Analysis
HX-1301: Tool Deflection Analysis
HX-1351: Shape Optimization
HX-1401: Defining User Area
HX-1404: Fitting a New Material into the Database
HX-1501: Post-Processing
