Hi!
I would like to export the animation with the 10 steps of my simulation in .avi format. How can I do it? Thank you very much.
Sincerely,
With Hyperview it's easy.
I am in Hyperview, but the only thing I achieves is a 1seg video where we see nothing. How can I record all the steps, please?
Try changing the settings in HV. Preference>> export options. Play with the frame rate values and the check the result.
I tried playing with the frame rate values but still the only thin I ge is a 1 s video where I can see nothing.
Do you have any other suggestions?
Thanks!
Hi Aurea,
Can you change the time delay between frames (in seconds)in export settings of GIF and try?
