Hello everyone,
I want to mesh a solid that I've created in a dxf file but when I import the geometry, I can only select lines from my geometry..
Is there anyone who can help me ?
Thank you.
i think dxf format supports line geometry only, you could try importing step data
I dont think you can do some mesh with DXF. Try IGES or STEP.
Ok thank you for your answers.
I'm now starting to work with the IGES format.
But can I have your point of view concerning these format, IGES and STEP.
My goal is to model a parabolic spring with some data with matlab, so the geometry is complex.
Which one would be the best for my work ?
i can not give you theoretical background, but from my practical expierence these formats are not very different, since both support volumetric entities. Personnally i prefer step-format.
Ok thank you for your answers. I'm now starting to work with the IGES format. But can I have your point of view concerning these format, IGES and STEP. My goal is to model a parabolic spring with some data with matlab, so the geometry is complex. Which one would be the best for my work ? Thank you.
1. STEP
2. IGES
3. Others
