hello,
I'm trying to create a shortcut for the save button. something like CTRL+S. Can someone help me ?
Thank you,
Sergiu
hello SCIUPARU,
try opening menu Preferences/Keyboard Settings
set Shortcut key is Ctr and click to 'S' virtual key
then you input below command:
HM_Framework:/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_SaveFile
this command is usually invoked when you click Save button
now you try Ctr+S to save your model
good luck
regards,
tinh
