Rigid Bodies Exporting
Niklasw94
Niklasw94 Altair Community Member
Hello together,
I wanted to export a model to another CAD program and I noticed that the Rigid Bodies didn't arrive in that program. I think only Geometry can be exported. How can I add something at the center of the rigid body that can be seen in any other program, like a little sphere or anything like that? Or ist there a possibilty to transform a rigid into a surface?
Thank you in advance!
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited May 2020
    You can use TCL script to create (geometrical) lines for each RBE. These lines will found within exported CAD.
  • Niklasw94
    edited May 2020
    Do you know which TCL Modify Command it is? I can't find something appropriate to do that.
  • QuyNguyenDai
    edited May 2020
    You do a loop over RBE.
        Foreach RBE, get his ID, dependant nodes, independant nodes,....
             Get coordinates for each node and draw lines
  • Niklasw94
    edited May 2020
    I made some now by hand but if I'd do all like that, I'd still do it in 2 weeks.
    How do you mean by loop over RBE? As is said I couldn't find any command of dragging a line. And the RBody Manager just shows me the ID of the Master Node, no coordinates..
  • QuyNguyenDai
    edited May 2020
    Here's my script:
    • Run it
    • Select some RBE
    • Lines are created within comp named 'RBE_Lines'
    • STEP is exported to '*_RBE.stp' in the same directory as HM model
    Script:
  • Niklasw94
    edited June 2020
    It's working! Thank you!
    Is the same process also available for a Spring2 element?
