Dear All,
I have got the new material in the Autoform : .mtb format & i want to use the same material properties in hyperform for the simulation.
If its posssible ,Can you please tell me what is the procedure to use the same .mtb format ? & if not then which are the ways to read the .mtb file to get all material property values??
Please suggest the good way ASAP
Sumit
