I'm working on a project on stress analysis of a typical truck chassis frame.
I need to mesh the chassis which contains 400 components, mostly nuts, bolts & washers.
Can I eliminate all the nuts, bolts & washers for simplified meshing?
Will it have an effect on the result?
Kindly help as I'm finding it difficult to mesh 400 components. Thank you (:
