I create a composite model which contains element offset in Patran/Nastran.When I import bdf in hypermesh, then I use 'card edit' to modify one of the elements. There is no information in Offsets(see first picture attached) ,but It really has offset values which is the same as I set in Patran/Nastran.Can you tell me why.And How can I set element offset except using card edit panel to modify element.
