Hi ,
I want to select elements, which are at a distance of 50mm from the top and bottom surface of the model.
My aim is to transfer solid elements from the design space into the non-design space.
Since , I have solver deck so there is no geometry available to create the void.
Problem is : how to select elements which are at 50 mm and cover region having dimensions 22 X 20 m. The existing model is in metre.
Is there anyway to do the same in HyperMesh?
Looking forward to your response.
Thank you.
