Hi friends,
I am a beginner in hypermesh. How can we define the warpage and aspect ratio for a model . Explain with example guys.
Hi friends' date=' I am a beginner in hypermesh. How can we define the warpage and aspect ratio for a model . Explain with example guys.[/quote']in element checking menu you could change those values and check the elements with those criteria, and you could save the faulty ones,another way is creating a criteria, you could create it from the meshing menu, create an advanced criteria table and then use them: 2d menu > quality index, there you could see some colorful things with your criterias.
if you want to use this parameters directly in the automesher panel, then try this:
*go to 2D->automesh
*on the left side switch to QI optimize
*press the green button 'edit criteria'
*here you have your criteria table too
*you can change the values und choose the method of criteria calculation (depends from solver)
Regards Mario
