Hi everyone,
I am doing the heat transfer analysis of plate having thickness 300mm.In this problem, i know the temperature on both surface of plate and i just want to find out the heat transfer rate per unit area. Please tell me the steps to be followed. I am new to heat transfer analysis in hypermesh and not able to proceed further after updating the component with material and property. I have also searched for the tutorial in online learning (help). But unable to find.
Thank you
