when I try to open the Keyboard Settings the following Error applies:
can't read "p_control_key_file(C)": no such element in array
while executing
"set file $p_control_key_file(C)"
("eval" body line 1)
invoked from within
"eval set file $${file_array}($key)"
(procedure "p_KeysToTable" line 23)
invoked from within
"p_KeysToTable 2 p_control_key_proc p_control_key_file"
(procedure "::HM_Framework::p_AcceleratorDialog" line 24)
invoked from within
(menu invoke)
I already tried to run the script KeyCommandTable.tcl. It doesn't work.
Thank you for your help
Christina
