I built a MBD model and I want to do modal analysis of this model. Please tell me is there any command or anything so I can do modal analysis. Basically I dont know how to start modal analysis.
In the 12.0 'run' panel, please select 'Linear' for the 'Sim Type'.
In addition, you will need to add the following .xml command template:
<H3DOutput
linear_animation = 'True'
This command will create an animation for all the modes in the .h3d file.
For more information about creating .xml templates, please see the tutorial MV-1051.
For more information regarding .xml commands, model statements, functions, and user written subroutines please review the .xml reference guide:
help->HyperWorks Home Help->Reference Guides-> MotionSolve
MotionSolve uses a .xml formatted input file that is generated by MotionView.
Hope this helps
