Which Card Image to use?
Heya,
Up until now I've only been meshing 2D structures, and have always used PSHELL.
Now I need to run an analysis on two objects (below). One is 3mm sheet steel, the other a hollow pipe.
Should I use PSOLID for the sheet steel, and PTUBE for the pipe?
Thanks!
