Dear,
During the optimization of our carbon monocoque I get the following error:
*** ERROR # 1800 ***
Stress/strain/force responses are applied to element 1 which
belongs to a topology or free-size domain. For stress-constrained
topology or free-size optimization, please use the STRESS option
on the design variable definition card.
I have done a continuous sizing with only the displacement of a torque as response/constraint to get the correct torsional stiffness. This step was successful and got me a result. I went further with these files to the next step. Namely adding manufacturing constraints and adding an extra static stress response/constraint to prevent failure from some specific loadcases. This gave me error 1800 as mentioned above.
Is this the correct time during the optimization to include the failure criterium? According to the tutorial it is done in this step. Instead of static stress I also tried failure index as a response/constraint with the same error as result. What is the correct method to implement this important constraint?
Kind Regards,
