can I merge these surfaces, like seen on the attached screenshot?
Thank you!
Hi, can I merge these surfaces, like seen on the attached screenshot? merge surfs.png Thank you!
Hi
if you have lots of such surfs, try using Geom>autocleanup
If you have few, use quick edit 'F11' toggle edge
