Good afternoon,
I would like to know again how to defined contact between two shells that are apart by there solid thickness,
It should respect the thickness during the contact.
Shells have T thickness defined.
One shell group is 30mm thick and the other is 25mm thick.
The 2 contact pairs are 27.5mm apart.
http://i.imgur.com/Q0dT71l.png
Where do I add the information in the cards again to tell the contact group the correct thickness of the shells.
Regards, Harry
