i have to optimize the semi-apical angle of it. so it is defined in radioss. how i can define design variables in it.
Please refer Hyperstudy Parametrization based tutorials.See attached screenshot.
Regards
Rahul R
its OK but how shape is parameterized for impact test in radioss
Hello ,
I think the tutorial below would guide you. You need to produce your shape variable with HyperMorph and HyperMesh. After that you can define the optimizastion study with HyperStudy.
thanks for your reply
in message it shows
generating design for(.............)
but file is not generated in approach directory or its subdirectories
unknown type of file is generated instead of t01. same prob with tutorial 4420
following is zip file contain snapshots and file generated in approach folder
Hi Rahul,
I didn'd find the Parametrization tutorials in HyperStudy, I used my Altair connect account :
I used another FEM software where the parametric study is very easy to run, you give N values of a parameter (Young's modulus for example) and you get N results, everything was managed by the software. Is there an equivalent ?
Thank you !
Please refer HyperStudy online tutorials.We have no of parametrization tutorials available. PFA screenshot from help.
You can also refer solver based tutorials section.
