How to brick mesh pipe for CFD?
I'm trying to brick mesh a straight pipe for OpenFOAM CFD, meaning I need a boundary layer, shell elements on the outer surfaces and a core - all hex elements. My meshing attempts up to now were only partially successful. I created a boundary layer by splitting the solid in an inner and outer pipe, then subtract one from the other, deleting the solid so I've got the inner and outer surfaces, created a surface mesh, then brick elements by using Element offset for the boundary layer. Unfortunately, the shell elements are lost in the process and I don't quite know how to create shells from the existing solids. Project nodes does not seem to be the right tool.
If someone could post a general workflow for this type of brick meshing I'd be very grateful. I've only used CFD tetramesh up to now, but OpenFOAM does seem to prefer brick elements. Unfortunately, I can't use hex core with a tetra oder penta boundary layer and transition, OpenFOAM can't handle different element types at once.
Edit: Sorry, this should have been posted in the Hypermesh subforum!
Some pictures? Share model HM?
0 -
I just noticed that the shell mesh I use for the element offset is preserved, so my previous post is partially wrong. I used the outer circumference as source meshing surface, thus it's the only surface containing shell elements. Now I need to create a matching surface mesh on the remaining inflow/outflow surface and ensure connectivity between everything.
The pipe is 0.5m in length and 0.1m in diameter.
0 -
Thank you, looks promising. But that does not resolve the issue of the surface mesh, unfortunately. How can I get a matching mesh on every outer surface from the solid mesh or vice-versa? OpenFOAM needs those to define the boundary conditions.
0 -
Go for solid mesh firstly. When you have good solid mesh, surface mesh will be extracted easily by using 'Tool' => 'faces'.
0 -
Huh, that was a lot easier than I thought. Thanks a lot!
0 -
Wonderful, I managed to get a good mesh with this method! Thanks again. I'll remember that in the future.
