Hi all,
I encountered the problem that the status shows that the Solidworks file is ready to be imported in HyperWorks ( 2017 student edition), but I don't see my model.What should I do?
Thanks,
Kewei
HI Kewei,
Can you export in STEP or IGES format from SolidWorks and try importing the same in HyperMesh?.
Meanwhile, is it a SolidWorks assembly file (*.sldasm)?.
When you import and you see nothing it means that importation was failed.
Yeah, or nothing is in his *.sldprt file
HI Kewei, Can you export in STEP or IGES format from SolidWorks and try importing the same in HyperMesh?. Meanwhile, is it a SolidWorks assembly file (*.sldasm)?.
Hi George,
I also use STEP and IGES format, but same thing happened, and I still saw nothing. The file is the part, not assembly file.
Hi tinh,
I can see the part in SolidWorks.
Hi Q.Nguyen-Dai,
I also think so. Actually, my document is converted from another format, and the file can be seen in Solidworks, but can't be found in Hypermesh. Do you have some tips to solve this problem?
Hi Kewei,
Can you please share the file so that we can review the same.
How many MB is the Step file?
Sometimes hm hides geometry data
After imported, can you try exporting geometry as parasolid format then import it again
Hi Kewei, Can you please share the file so that we can review the same.
I don't have the copyright of the file.I will do it when I get permitted.
How many MB is the Step file? Sometimes hm hides geometry data After imported, can you try exporting geometry as parasolid format then import it again
The file is over 180MB. I think it is too large.
Just sharing some relevant information on import.please find attached file for your reference.
