We are not able to open the MVW file in Hyperview 14.0 for specific user. The Error is unable to open inp file and error math analysis we had tried lot of things but the file is not opening please suggest how to resolve the issue
Hi Raghunath,
Use File>>Open>>Session to open .mvw files.
If you are doing the same and you still get the error message, Check if the .inp file is available in that specific location.
Yes we are opening as same as above steps, Also we had checked .inp files all are fine. But this issue with 1 machine and specific user we are facing issue.. we had checked the user profile there is no issue with the user.
Error : Error Creating Result math analysis.
We also tried with latest version 14.130 the issue persists.
Can you share the entire screenshot of the error message dialogue box?
Also, what is the version of Abaqus used to generate the .inp file?
Please note: if you are a commercial customer, you can contact your local support @ http://www.altairhyp...ortProduct.aspx
