Error # 6001, 2 vectors are defined on DTPL, 1 aligned
Hello at all,
during a topology optimization of a wireframe of a student racecar the check before optimizing gives the following error:
A fatal error has been detected during input processing:
*** ERROR # 6001 ***
Two of the vectors defined on DTPL card 1 are aligned.
I don´t know what to do now.
At the end of this text i add a dropbox link to my hm-file, so maybe someone of you can have a look and give me tipps to solve my prob.
I guess it could be the connection between the beams (1D) and the design space (solid). i equivalenced them with the equivalence function (in menu SHIFT+F3) in compliance with a small warpage. Maybe the local vectors of the beams are incorrect now.
I don´t have any idea.
I hope there is someone can help me.
greets,
Thomas
https://www.dropbox.com/s/evz55axqz5ru4r0/TEST_MOdell_7.hm?dl=0
Thank you so much,
now it works /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
I was quite sure that i paid attention choosing the right nodes /emoticons/default_sad.png' alt=':(' srcset='/emoticons/sad@2x.png 2x' width='20' height='20'>
Thanks a lot,
Greets
Hi Rizo,
You have defined the same node location for first and second node in pattern grouping.
Please choose another node for either first or second node.
