Tape between different surfaces
Altair Forum User
Hi, i'm using hypermesh as pre-processor and performing some FEAs with Nastran.
i'm looking for a way to create in my hypermesh model the new BCTABLE e BCCONECT that are used starting from nastran 2013.1.
In other words, I need to put in Hypermesh something like this:
$$------------------------------------------------------------------------------$BCBODY1,201,,3D,DEFORM,101BCPROP,101,4BCBODY1,202,,3D,DEFORM,102BCPROP,102,9BCBODY1,203,,3D,DEFORM,103BCPROP,103,90$.......$.......$.......$.......$.......$.......$.......$.......$.......$.......$.......BCTABL1 0 2001 2002BCONECT 2001 3001 203 201bconect 2002 3002 203 202bconprg 3001 IGLUE 3 ICOORD 1 ERROR 0.005 COPTS 61 COPTM 61bconprg 3002 IGLUE 3 ICOORD 1 ERROR 0.007 COPTS 61 COPTM 61BCTABL1 1 2001 2002BCPARA,0,NLGLUE,0$$------------------------------------------------------------------------------$
since i'm a little bit tired of use the old-fashion-way to insert this on bdf file.
I do not understand what you described
But to import/export this new data, it is possible by customizing nastran template and reader
0 -
This is not what i want. I need to create a contact table like the example I gave, but using Hypermesh
0 -
Ask altair hotline what version of nastran that hypermesh support till now
if it not nastran 2013 then customizing template is exactly what you need to do
do you try looking for name of the cards in pulldown menu Tools>Create Cards ?
