Legend in Hyperview
Updated by Altair Forum User
Hi!
Is it possible in Hyperview to adapt the legend by just entering the maximal value. I want to compare different simulations and since the max value is not the same, the same color does not mean the same stress. I know you can adapt every single value of the legend manually, however this is to much effort. I'd like to just enter the range e.g. from 0 to 2Mpa and then it should linearly assign the other colors to the corresponding values. Is that possible?
Best, Jonas
1 - 2 of
21
Altair Community Member
Updated by Mario_21478
You can do it also by editing the legend. Click the max. and min. values and change it to what you want.
Best Regards,
Mario
Hi
Please try the below highlighted option.
Thank you
