In some cases The ' EW_BATCH Failed: TCL_ERROR ' appears at the beginning of the analysis processing! Could it be possible to let me know what would be the matter?
Dear Mehran,
Are you running your model or the models from training document? Please go over training models first before you start working on your models.
The status windows may not show complete state of the issues. What you need to do it go to the folder in which you are running the simulation. Open file 'Status-EWB.log'. Look at last few lines in that file. That will guide/reflect what is happening.
Also you can attach that file and we will know what is the issue.
Dear Narendra Singh,
I have checked the 'Status-EWB.log' file which you have mentioned.
The Problem is meshing the Portholes in my model, but I can't find the exact reason of that! What would be the issue in your mind? Also, the model is attached to this message. I will be appreciated your help.
Sincerely,
1. Can you please confirm if you have tried all training models?
2. Can you please confirm which version you are using? Latest version is 2018. Your model is working with 2018. I have not tried in older version.
