since there are only few settings to play around with, is there anyway to improve the accuracy of FEA result? my result is way way off comparing to the experiment.
Since it uses simlab in backend for creating tetrahedral element.It is good to check element quality of tetrahedral element like tet collapse.which should be more then atleast .1.
and if you are talking about Inspire Stress results then for better accuracy you can check the results in Hyperview.Because it gives more option for viewing stress results like Nodal, elemental, simple, averaging etc.
As Prakash mentioned remove thin areas beause it may lead in to some bad quality elements. (Inspire writes fem file which you can open in Hypermesh and check element quality)
Regards
Rahul R
You will have to recheck the conditions of the analysis, are the loads applied and distributed exactly as in the experiment, constraints, material properties, is it linear or non linear etc
also make sure the run is set to 'more accurate' rather than 'faster'
Hi, Since it uses simlab in backend for creating tetrahedral element.It is good to check element quality of tetrahedral element like tet collapse.which should be more then atleast .1. and if you are talking about Inspire Stress results then for better accuracy you can check the results in Hyperview.Because it gives more option for viewing stress results like Nodal, elemental, simple, averaging etc. As Prakash mentioned remove thin areas beause it may lead in to some bad quality elements. (Inspire writes fem file which you can open in Hypermesh and check element quality) Regards Rahul R
Hi Rahul,
you are writing that inspire creates fem files that can be opened in Hypermesh, right? I am a beginner with the altair software suite, I am not yet familiar with the handling of their applications. Could you give me some sort of Click by click order of how to display my results in hypermesh and Hyperview? and what files can be opened in which application?
that'd be great help!!
thanks
Hi Rahul, you are writing that inspire creates fem files that can be opened in Hypermesh, right? I am a beginner with the altair software suite, I am not yet familiar with the handling of their applications. Could you give me some sort of Click by click order of how to display my results in hypermesh and Hyperview? and what files can be opened in which application? that'd be great help!! thanks
For importing .fem into Hypermesh, please do :
Screenshot: http://s12.postimg.org/l3gh886q5/HM_Import_Solver_Desk_Optistruct.png
Alright!!! Thank you!!
