I am working on a aircraft model having span of 80 m.
What should be the appropriate size of the model so that the meshing can be done ?
What size can be handled by HyperMesh without giving 'not responding' problem. This problem of 'not responding' usually comes.
Right now, I have scaled it down to 40m and meshing done with element size of 0.05 mm. Very fine mesh created using 'tria' elements. It has to be used in VWT so , tria elements are used.
Is the scaling appropriate ? Do I need to scale it down more?
Thanks
Garima
