I've successfully created a model optimised using lattice capabilities in HyperMesh. The model contains areas of solid and lattice structures. I am attempting to export this into 3-matic and convert to an .stl file.
The first process I tried was:
Exporting the lattice HM file to .fem with a Filetype= Optistruct and Template=Long.
I imported the .fem file into 3-matic using the remesh module.
This worked well for the first time I used 3-matic and showed the lattice clearly.
I am now trying again and the lattice is not showing at all in 3-matic, even with the exact file that worked the first time.
Any help will be much appreciated.
Thanks
