I have a model of a plate with many holes that need to be fastened to a beam. I want to make an optimization with Hyperstudy to know where I need to put the bolts to have the minimum stress inside the plate. How can I define my model in Hypermesh, in which Hyperstudy will be able to create all the possible combinations of bolts position for a DOE ?
Thank you,
Benjamin
