Ply orientation, RADIOSS Block format 110
I'm modeling a container with shell elements and composite material (Material Law 25) in hypermesh and Radioss block format 110 for an impact performance.
I applied to my model a property P10_SH_COMP (with a 0/-45/45/90 stack) for each faces of the box and assign a vector to give the default orientation for each face.
But when I request the layer orientation in Hypergraph (with /ANIM/SHELL/PHI/ALL) , I obtain a weird result as you can see on the attached file. Some elements have -135° and others have 45° on the same face.
And this is happening for each face of the box. I checked the normals of the element in Hypermesh but all of them have the same direction.
Maybe you have the solution to my problem ? (This maybe not has an influence on the final result in term of stresses but could be a good idea to know what it's happening for further studies).
Thanl you !
Hi ABIARD
Does your model have local system for orientation?
ANIM/SHELL/PHI outputs the angle between element system and direction 1.
Can you share your model using the dropbox link in below signature to see how it is modeled?
0 -
I sent you the model in the dropbox.
And I didn't setup any system in my model, I just indicated a vector for the orientation by nodes.
0 -
Thank you for sharing the model.
I will look into this and will get back to you soon /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
0 -
hi
I want to change material orientation
how to change it
note: I use P10 sh_comp for my model
0 -
NO IT IS NOT WHAT I ASKED
IN 2D, COMPOSITE - MATERIAL ORIENTATION IS HERE
HOW TO CHANGE MATERIAL ORIENTATION
0 -
ok thanks
but in there, what is function of VX, VY and VZ
HOW TO MODEL WOVEN COMPOSITE
0 -
Vx, Vy and Vz are x,y and z components (global coordinate system) of a vector V which defines material orientation. Those are filled in automatically when you reference by nodes.
Woven composite is modeled by inputting the same Young's modulus E11=E22 into material law definition.
