I have two components one of which is a shell and the other is a solid. Some protion of the shell surface overlaps with one face of the solid. Both have very complex shapes. How can I have the same mesh on the overlapping surfaces and connect these shell and solid elements? this is analogous to a plastic sheet (shell) reinforced by a thick layer of foam (solid). It will be great if it is possible to mesh the shell first and then the solid.
Thanks
