Hello Y'all,
I have a question about units on Hypermesh.
So, my problem is that my model in Solidworks is in MMGS, but when I import it into Hypermesh and measure it I see its in meters there. (850 mm in Solidowrks and .85 in Hypermesh). I know I can use the scale factor and scale it by 1000 to get the model in MMGS, but does this mean I will have to change all my data for the material too. I am using the mm, s, Mpa, tonne unit system for data. And what units will my result be in?
Thank You
Saahir
