Hi all,
Using the Melt Flow Macro in Polymer Processing user profile, I can't find in the directory the '.h3d' file with results after exporting the model with 'Save and Export' window.
regards,
Stefano
Hi Stefano,
The melt flow wizard helps you to setup models for polymer flow analysis.
So, When you save and export a solver file will be written which is ready to solve.
You will get the result file only after solving the analysis.
