When I am importing the pressure extracted from the VWT analysis to the model in HyperMesh.
I am getting the value of pressure as zero and in contour loads option - I get 'no results available for contour'.
I have used AcuOut to export 'pressure' in 'table' format and 'nodal Output' type .
I can see pressure values in the .OUT file but when I am importing , no pressure values are being assigned to PLOAD4. (Snapshot attached).
I had earlier raised this query in AcuSolve forum but they have suggested to put it in this forum.
How can I solve this issue? It would be nice , if somebody can help in sorting this problem.
Looking forward to a timely response.
Thank you.
Garima
