I want to perform die structural analysis of a forming die using 'Die Stress Analysis' in Die Module of HyperForm. The tool is in the form of plates (not of casting type) and all die, die housing, etc., all palrts are separate and fasten by bolts. I want to perform linear static analysis for only punch and die blocks with the operation loads.
I have refered the repective tutorial 'HF-6000: Die Structure Optimization'; but I'm not clear with the procedure yet.
How do I mesh the components (3D?; which type volume tetra?)
How can I skip 'Transportation' subcase?
Or Simply
If I decide to do the linear static analysis in HyperMesh, how can extract the contact forces and apply them to my model?
