Which element do you use usually for bolts instead of rigid?
What properties and materials should i use for bolts?
Thanks in advance.
Please go through this webinar: https://www.youtube.com/watch?v=-HdECgBC_lM&list=PLQ7KUGFuVz4u5y3SvIEIU07427-gATaG6 which explains about modelling connections for HyperMesh - RADIOSS interface and everything related are covered in this webinar.
Hi Semih,
Did you find the answer to your question? (which is also mine). According to me the video linked in the answer doesn't answer to your question...
