I'm trying to use superelement to simplify a model and focus on a single component of this model.
the loading is composed of :
- gravity load
- imposed displacement using SPCD.
this loading is not directly applied on the component I am trying to isolate and thus should be included in the PAX.
When I generate the .pch file and use it in the simplified model the obtained results (deformed structure for instance) are very different from the ones obtained with the original model. It seems that the inforced displacement is not taken into account. This assumption has been verified as I removed the SPCD from the original FEM and obtained the same results as with the condensed MEF.
is there any special care to take when using DMIG and SPCD? Are they compatible?
thank you
